homenet_local
Dec 30, 2020Tutor
Trying to connect Netgear Mobile Hotspot MR5000 to Netgear Nighthawk R7000P Router
** Please note the Model above is not correct, this website does not have the new MR5000 Hotspot as an option, so I selected the closest one. Good morning, I am trying to "upgrade" my old set up ...
homenet_local
Jan 06, 2021Tutor
Sadly it looks like the new R7000P configuration is still lacking. Video calls are dropping in and out, bandwidth seems to fluctuate widly from 1-5MBps to 15MBps but stays more on the lower end consistently and devices are loading webpages very slowly. Video calls are choppy. Any other ideas?
Jan 07, 2021Guru - Experienced User
got an old router sitting around you could try? or someones you could borrow to try?
