Pinkertonk
Jul 09, 2022Aspirant
Trying to connect Nighthawk Mesh MR60 to Nighthawk hotspot MR6400
 The setup says it is not compatible.  They are both Netgear Nighthawk devices so I don't understand that.  This is one of the new Dish Genesis 5G hotspots.  I'm on the latest firmware version.  Ive g...
Jul 09, 2022Guru - Experienced User
Thats because they are NOT compatible.
You could only use the MR60 in AP mode ethernet connected to the MR6400 is all.
Pinkertonk
Well Crap! So I need to have a mesh network in order for this hotspot to be usable at my home. What mesh systems will work? I currently have cable internet with EERO mesh system (1 router and 2 sats) that works fine. It's leased and I'm wanting to get away from cable internet and go with this Dish Genesis 5g hotspot.
- FURRYe38Jul 09, 2022Guru - Experienced UserNot sure if this hotspot can disable it's wifi radios at all or can be used in a modem only configuration. If thats possible you could use any wifi mesh system with the MR6400, however I don't have any experiences when it comes to these model units. If you can get it into a modem only mode or shut off it's wifi radios, then it's possible to use a wiif mesh system in AP mode with this unit. I would refer you to the user manual on any operation modes the MR6400 may have and or see if the wifi radios can be turned off. - PinkertonkJul 09, 2022AspirantThank you but I've reached the end of my technical knowledge. AP mode? I realize the wifi uses RF to broadcast but what are WIFI radios called on the configuration page. The installation and user pages are vague to say the least.
