Mathias87
Dec 21, 2019Follower
trying to reset admin password on mr 1100
So ive tried using "admin" and "attadmin" and "password" but none are correct. i must have changed the password and now dont know it. ive tried to do a factory reset but i have to be able to login to do that.....any help would be much appriecated.
1 Reply
> [...] mr 1100
There's a more appropriate forum for such devices, where you might
find/get better information sooner:https://community.netgear.com/t5/x/bd-p/aircard
> [...] ive tried to do a factory reset but i have to be able to login
> to do that. [...]Not according to the MR1100 User Manual. Visit
http://netgear.com/support , put in your (actual) model number, and look
for Documentation. Get the User Manual. Read. Look for "Factory Reset
Using the Reset Button" (or "reset").
