Rahooool
Oct 25, 2020Aspirant
Turn off Nighthawk 5 Ghz network
Just bought this MS60 Nighthawk Mesh. Had a Netgear for 10 years before this and never had such trouble. Guest Network broadcasts on 2.4 Ghz and 5 Ghz. They both have same SSID (Previous Netgear rout...
Rahooool
My previous router was a Netgear MR814. The guest network there allowed me to enable or disable the 5Ghz and it had a separate SSID.
The new MR60 Nighthawk Mesh with 2 satellites was setup with the same SSID, WPA2 password. All the devices in the home automatically recognized it and connected which was great. The guest network uses the same SSID for both 2.4 and 5 Ghz and this is not configurable on the App or via browser.
I connect the HP 8600 printer to the guest network and a few devices are connected there as well. Some devices (mobile phones, tablets and laptops) are able to detect the HP printer and others are not. What I noticed when I checked was the devices connected to the Guest 2.4Ghz are able to connect and detect the printer on the 2.4 Ghz but the devices connected to Guest 5Ghz are unable to find the printer. I tried to configure them by IP address of the printer as well but it still doesnt find it.
I connected the printer and the laptop (Dell Inspiron) to the main SSID (Non Guest). Both connect and work fine. Its only when I connect to the guest network, the printer always connects to 2.4Ghz and the laptop to 5 Ghz and they cant seem to communicate. Seems like the 2.4 Ghz guest and 5 Ghz Guest do not communicate with each other. Not sure what else could it be
Rahooool
My son's friends come over often enough and print stuff and I dont want anyone else on my main SSID so i keep the printer on Guest. But you are right I probably should just keep it on the main SSID
I dont see the Allow guests to see each other option... going through all the choices on this one but thanks for the direction
