coolwhiff
May 16, 2020Tutor
Unable to flash MR1100-2A1NAS with Generic firmware
I bought an unlocked MR1100 (AT&T-branded). I'm trying to use it with T-Mobile (via TravelData unlimited LTE reseller). I'm using b2b.static as the APN (as instructed). I'm unable to get a data conne...
coolwhiff
May 16, 2020Tutor
Here's model.json
coolwhiff
May 19, 2020Tutor
Any ideas?
I'm about to either return the MR1100-2A1NAS and try to find a 1A1NAS (that's supposedly supported); or switch to neverthrottled (which is on AT&T's network which the 2A1NAS would, I assume, work with).
- icarusponyJun 20, 2020Luminary
You skipped telnetting into the MR1100 on port 5510 to issue the AT!BOOTHOLD command before using FDT.exe.
- coolwhiffJun 21, 2020TutorI had done that (pretty sure... Was a while ago). I eventually switched services to another data provider that used AT&T instead of T-Mobile). And then eventually returned everything because even with a weboost signal booster mounted on the roof I couldn't get a strong enough signal... So back to looking for a neighbor with Comcast access that I can set up fixed wireless to.
Good luck all and thanks for the reply! - YekingAug 18, 2022Aspiranticaruspony Can you pls put me through, i have MR110 in a boot loop but i can put it in downloading software screen the only i don't do right is loading through fdt. there're things i dont do right and it won't reload the os
