hotwater9
Apr 07, 2019Aspirant
Unable to get LB2120 modem working with my RT2600ac router
I am trying to get my LB2120 setup as my fallback internet connection on my Synology RT2600ac router. I have the modem set to bridge mode with the default IP address. For the connection type in my router what should I select. TManual, auto or PPPoE? These are the options for manual.
Two points:
Keep the LB2120 in router mode, so it acts as a local DHCP server
Your router (RT2600ac router) WAN/Internet port can be configured to one setting - so this is typically a plain TCP/IP DHCP config, no PPPoE or the like ... I think in case your primary ISP does require some encapsulation and authentication, you are out of luck with the LB2120 faiö-over config.
