kopiko
Jun 25, 2022Aspirant
Unable to save changes on Nighthawk M2
firmware version: NTGx24_10.19.03.00 last checked 13/6/22 modem version: SDX24_10.25.02.03 PRI 05.02 firmware build date 2021/09/01 I am unable to make any changes and save it. If I do it on ...
Blanca_O
Jun 30, 2022NETGEAR Employee Retired
Hi kopiko
Welcome to NETGEAR Community!
May we please know the device SKU (e.g. MR1100-100NAS)? This can be checked on the box of the product or on the barcode label
Have you tried using different browser? different device to change settings?
Is the device powered on without the battery in?
Blanca
Community Team
- kopikoJul 03, 2022Aspirant
Hello
sku: mr2100-a1tlaus
I usually have the router powered on by USB, no battery.
Just now I tried with Chrome on a laptop changing the wifi profile from dual band to 2.4 only and it gives me a popup saying I will need to reboot the router for the changes to be applied. It says applied but when I reboot it says "rebooting"
I left it for 5 minutes and pulled the power and repoweredThis time I tried it on Edge.
Again, no battery, tried same thing but waited 7 minutes this time for it to reboot before pulling the power.I tried again, now with the battery plugged in, no USB, in Chrome. It is stuck on applying changes.
I connected my mobile phone to the wifi and tried changing the wifi profile, same thing, stuck on "applying"- Blanca_OJul 05, 2022NETGEAR Employee Retired
Hi kopiko,
Aside from this issue, do you have connectivity issue such as connecting to the network or intermittent connection?
As this is a Telsta SKU, have you tried contacting them regarding this concern?
Blanca
Community Team- kopikoJul 12, 2022Aspirant
I took it to the Telstra shop and they said they could send it in to be looked at/repaird but it will cost money and to come back on a weekday when the something manager was in. I haven't been back since.
I think it has something to do with the firmware and it's been corrupted during an upgrade. I just want to factory reset it because when I first received it, it was fine. I think I may have unplugged the power while it was updating.
I saw somewhere that the "factory reset" button isn't a full factory reset.. but to hold the reset button while cycling through power/no power/power but all that brought up was something like downloading software and that didn't fix the issue. How long was I meant to leave it on "downloading software"?
Why does it cost money to factory reset properly?
I didn't know it was set to "automatically update." Is there a way to turn off this setting
I would say it impacts internet connectivity. At the beginning my laptop would only connect via ethernet. I think after i did the above power cycle, it's able to connect to the wifi now. but even now the laptop is showing it's connected to the wifi but no internet. But i can browse the internet.
