icantdance
Feb 25, 2025Initiate
Unable to save changes to WIFI Network Name on Nighthawk M3 MH3150
I can't save any WiFi changes on my new Nighthawk M3. I have followed the instructions in the manual, but the Apply button is disabled. I've tried on my phone and on a laptop and get the same problem...
- Feb 25, 2025
Have you tried configuring the WiFi immediately after a factory reset?
Main_Tag
Mar 05, 2025Guide
Hello,
I had the same issue but when you change the security to WPA/WPA2 or to none, you can change the ssid. After that you can change the security back to WPA 2 / WPA 3.
best regards
- 62dediMar 05, 2025Aspirant
Hello,
unfortunately this solution doesn't work for me either. I can confirm the changes (ssid and password, encryption), but then I can no longer change the encryption again.
Regards, Detlef
