icantdance
Feb 25, 2025Initiate
Unable to save changes to WIFI Network Name on Nighthawk M3 MH3150
I can't save any WiFi changes on my new Nighthawk M3. I have followed the instructions in the manual, but the Apply button is disabled. I've tried on my phone and on a laptop and get the same problem...
- Feb 25, 2025
Have you tried configuring the WiFi immediately after a factory reset?
Main_Tag
Mar 06, 2025Guide
Hello,
I reproduced the error and found a solution that worked in my case.
You need to open the web browser and login to your m3.
After that you need to go to the Wlan menu and change the encryption method to none (do not safe!). Then you can change the Password and the SSID (do not safe at this point either). Then you need to change the encryption method to the previous method in my case WPA2 / WPA3.Now you can safe the settings.
Make sure to save you're settings at the beginning.
Best regards
62dedi
Mar 06, 2025Aspirant
Hello,
I tried it again and now it works!
In contrast to the first attempt, after switching to "no encryption" I did not confirm, but changed the SSID and PWD. Then I switched the encryption back to WPA2 WPA3 and then I was able to confirm.
Thank you very much.
best regards
