icantdance
Feb 25, 2025Initiate
Unable to save changes to WIFI Network Name on Nighthawk M3 MH3150
I can't save any WiFi changes on my new Nighthawk M3. I have followed the instructions in the manual, but the Apply button is disabled. I've tried on my phone and on a laptop and get the same problem...
- Feb 25, 2025
Have you tried configuring the WiFi immediately after a factory reset?
EXaXXion
Jan 25, 2026Tutor
Hello,
I have the same problem, I solved the WIFI name problem with a factory reset.
But now I want to change the encryption to WP3 and the problem is the same, the "apply" button is disabled.
Also I cannot use my standard mobile PW for all my mobile router, because of a special key inside of it. How could that be fixed on the M3?
