pacmania1982
Jan 04, 2023Initiate
Unable to see WiFi when dual band is selected on MR1100
Hi guys I just received my Nighthawk M1 (MR1100) portable router. I turned it on and let it boot up but couldn't see the default SSID on my iPhone. I tried my iPad and got the same results. I tri...
Jan 04, 2023Guru - Experienced User
I'd exchange it.
It should be broadcasting both at the same time.
You can always try a factory reset before you do.
Plus make sure its on the latest firmware.
