WaffleMoney
Jan 08, 2022Aspirant
Unable to set MR1100 as dedicated modem for deco mesh system
I've been doing 'ok' with the settings so far, though I'm getting a lot of random issues, such as double NAT warnings and strict settings. I found, and it makes sense, that my MR1100 is serving as t...
JohnPeng
Jan 09, 2022NETGEAR Expert
Please let me know the SKU name and FW version of your device.
Thanks
- WaffleMoneyJan 09, 2022Aspirant
SKU: 6112B (Oddly not the typical sku I see out there)
FIrmware: NTG9X50C_10.20.05.00
Oddly enough I thought I had updated this but it is showing stuck at 0%, Downloading.
I do not have the option to upload the firmware file, which I have downloaded. The option is completely removed and I only see the 0% status bar.
JohnPeng wrote:Please let me know the SKU name and FW version of your device.
Thanks
- WaffleMoneyJan 11, 2022Aspirant
Thanks
Thank you for any help on this. If my MR1100 is dead, I need to sort this out quick to get my internet up to speed. The joy of living in rural areas.
- JohnPengJan 11, 2022NETGEAR Expert
Yours is AT&T M1. To set the M1 as dedicated modem, you can try to disable Wifi and enable IP Passthrouhg on M1. Then connect the mesh system to M1's ethernet port.
To upgrade your device to the latest release, please do a factory reset and try again.
Thanks
JohnPeng wrote:Yours is AT&T M1. To set the M1 as dedicated modem, you can try to disable Wifi and enable IP Passthrouhg on M1. Then connect the mesh system to M1's ethernet port.
Thanks
Thank you for the reply. It's frustrating that the firmware page redacts the ability to manually upload the file. Oh well, I'll give it another shot.
