WaffleMoney
Jan 08, 2022Aspirant
Unable to set MR1100 as dedicated modem for deco mesh system
I've been doing 'ok' with the settings so far, though I'm getting a lot of random issues, such as double NAT warnings and strict settings. I found, and it makes sense, that my MR1100 is serving as t...
WaffleMoney
Jan 11, 2022Aspirant
JohnPeng wrote:Please let me know the SKU name and FW version of your device.
Thanks
Thank you for any help on this. If my MR1100 is dead, I need to sort this out quick to get my internet up to speed. The joy of living in rural areas.
JohnPeng
Jan 11, 2022NETGEAR Expert
Yours is AT&T M1. To set the M1 as dedicated modem, you can try to disable Wifi and enable IP Passthrouhg on M1. Then connect the mesh system to M1's ethernet port.
To upgrade your device to the latest release, please do a factory reset and try again.
Thanks
- WaffleMoneyJan 11, 2022Aspirant
JohnPeng wrote:Yours is AT&T M1. To set the M1 as dedicated modem, you can try to disable Wifi and enable IP Passthrouhg on M1. Then connect the mesh system to M1's ethernet port.
Thanks
Thank you for the reply. It's frustrating that the firmware page redacts the ability to manually upload the file. Oh well, I'll give it another shot.
