EdOhio's avatar
EdOhio
Follower
Aug 17, 2017
Unite Explore: Is it necessary to unplug charger after battery fully charged?
This is about the AirCard 815S Mobile Hotspot "AT&T Unite Explore" which is not an available model number in the dropdown menu.  When the Lithium battery is fully charged, the hotspot screen says, "Please disconnect charger."  I want to use this device in a place where the charger is able to be plugged in.  Can I just leave the hotspot plugged into the charger, or will this create problems with the battery?  The user manual is silent on this issue.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    I would pull the battery if you want it plugged in all the time.
    DarrenM
