mjcxp2
Feb 09, 2016Follower
Unite Pro 781S Unable to update Firmware
I am unable to update the firmware on the AT&T 781S Unite Pro Hotspot. When I click on "Check for update" I either receive a message that there is no update availableor that an error has occured. I also try updating through the webportal(http://attunitepro) and receive the same error when updating. On the AT&T website it shows that an update was released on August 19, 2014 (Software version: NTG9X25C_01.00.57.03). Is the update server down? If so who should I contact... AT&T or Netgear? Below is my current software.
Device Model AirCard 781S AT&T Unite Pro Manager: http://attunitepro Firmware Version NTG9X25C_01.00.17.00 Firmware Build Date 10/18/13 PRI Version 01.08 Firmware Firmware Version NTG9X25C_01.00.17.00 Firmware Build Date 10/18/13 Web App Version AC781S_03.02.43.01 Bootloader Version NTG9X25C_01.00.17.00
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello mjcxp2
You would need to contact Att on this they handle all the support for this device.
DarrenM
