sanji99's avatar
sanji99
Follower
Feb 02, 2022
Unlimited plan for Netgear Nighthawk M1
I just bought a house in a rural area and so far it seems my best option for speed is the netgear hotspot but I am concerned with the 50 gb data caps as I am a heavy internet user. Does anyone know of an unlimited data plan for this hotspot? Or secondarily Does anyone know what the overages are or what your data is throttled to on att or t-mobile? I game and occasionally work from home.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    That depends on where you live, which operators there are, and other stuff that has nothing to do with the hardware you choose.
    Netgear doesn't run a mobile phone network. Tell people where you are and someone might be able to help, but you might do better to talk to the neighbours.
