Edrees
Dec 24, 2017Follower
Unlock code for Nighthawk M1
Hi, i have the Nighthawk M1 router from Ooredoo and i want to use it with other carrier. When i put other sim card other than Ooredoo it says unlock code is required. So how can i unlock it? Model:...
assa2005
Apr 09, 2018Initiate
No this was not helpful at all, you didn't add anything useful.
What actually happens is that these companies are fooling the customers by help of Netgear or otherwise. The customers should be clearly told that the device that they pay for is unusable with a different SP, and they are free to decide.
In my case, if I knew that I wouldn't take it, I had to buy it from that specific SP because it's not available in the local market anywhere else.
JasonN
Apr 13, 2018NETGEAR Employee Retired
Hi assa2005,
They are correct. You would need to contact that ISP and have them unlock the device for you.
Please keep us updated. :]
- Jason N
