tobys's avatar
tobys
Unlocked MR1100-1EEEUS
Once carrier unlocked (by using EE codes provided at end of contract period), what is the difference between their version and others?
from a previous discussion - "The MR1100-1EEEUS is a Europeran version, like the -100EUS, however it's provider locked to EE UK network."
I'm haivng diffiuctly finding firmware that will install as I'm getting "not supported on this device" errors.
Thanks in advance,
Toby.
1 Reply
  • The difference i saw is bands CA
    For example in UK version the band 40 doesn't aggregate with itself but in the EUS it does .
    Also UK has B3+B28 and the EUS has B3+B28+B1
    I dont know if there is another difference in the other bands combo's.
