nchammer
Aug 17, 2021Aspirant
Unlocking Nighthawk MR1100 Instructions
I have requested an unlock code from AT&T. I have not found step-by-step instructions for entering this unlock code specific for the MR1100 using the wifimanager. Any assistance?
AyeAyeAye
Aug 19, 2021Apprentice
Put in another non AT&T provider sim, it should ask for unlock code when you login in M1 user interface
https://www.att.com/ecms/dam/att/consumer/help/2016/pdf/ATTMobilityDeviceUnlockCodeInstructions_082120_SO_FINAL.pdf#page17
- nchammerAug 19, 2021Aspirant
The instructions you provided do not include the Netgear Nighthawk MR1100. The instructions provided for the other Netgear devices are not availabe on the interface for the MR1100.
- AyeAyeAyeAug 19, 2021ApprenticeThey were for my M2.
Put in a alternative sim
I had to admin page and login then enter it, assumed M1 being between them^ and M2 would be the same.
