BrianPotts
Apr 26, 2021Follower
Unwanted restarting
Hi,
I have just purchased, through Telstra, a Netgear Night hawk M2 and it keeps restarting after I shutdown.
This may be problematic on flights.
Is my unit defective or is there a way of keeping it shutdown?
It appears it only needs a light touch to start it up.
1 Reply
- nighthawkm2Aspirant
Hi Brian,
I also have the Telstra Nighthawk M2 mobile router and unfortunately I don't think it's defective but the product in general or the combination from Telstra. I've had mine for 12 months today and rebooting normally happens once or twice per day and performance is less than that of my mobile hotspotting with the same network.
Though as of today mine has been rebooting every 20 minutes even on the newest firmware so it could be a Telstra network problem but I can't confirm this. It would be great if there is a solution to make it work, so far it seems taking the battery out for me is more reliable but not by much.
It's a shame when Netgear generally performs well but I can tell you after my experience, I'll be looking for an alternative shortly.
I'd just make sure you have the firmware updating and if at a location with power plug it in and take out the battery.
