Nazmi_Adnan
Oct 11, 2020Aspirant
Updating Firmware MR2100
Hello, im unable to updating my MR2100 Nighthawk M2. The updating never finishes. Im also realized that the clock at above between cellular and battery also is missing. Model: MR2100/Netgear Nigh...
Blanca_O
Oct 11, 2020NETGEAR Employee Retired
Hi Nazmi_Adnan
Welcome to NETGEAR Community!
Some carriers block the port used by NTP and this prevents the device from getting the correct time. Without the correct time, the device can't connect to the firmware update server.
We are working on the fix on the FW to resolve the NTP blocking issue.
A workaround is to enable data offloading so that the device can connect to NTP. Then the upgrade can be done.
Related thread:
Blanca
Community Team
