Nazmi_Adnan
Oct 11, 2020Aspirant
Updating Firmware MR2100
Hello, im unable to updating my MR2100 Nighthawk M2. The updating never finishes. Im also realized that the clock at above between cellular and battery also is missing. Model: MR2100/Netgear Nigh...
Blanca_O
Oct 11, 2020NETGEAR Employee Retired
Hi Nazmi_Adnan
Welcome to NETGEAR Community!
Some carriers block the port used by NTP and this prevents the device from getting the correct time. Without the correct time, the device can't connect to the firmware update server.
We are working on the fix on the FW to resolve the NTP blocking issue.
A workaround is to enable data offloading so that the device can connect to NTP. Then the upgrade can be done.
Related thread:
Blanca
Community Team
Nazmi_Adnan
Oct 12, 2020Aspirant
I've been try several time using offloading method, but also failed.
- schumakuOct 12, 2020Guru - Experienced User
Blanca_O I still don't see the point of using NTP (resp. get the time and date from an NTP or SNTP service). That might be OK as a second source if there is no mobile connection or no SIM in place. Preferred method for a mobile network device is always to get time and date from the mobile network.
