quten
Feb 27, 2024Aspirant
Upgrade orbi ac6000 need help with layout plan
I need some help with a setup, a friend currently has the Orbi Pro AC3000 router with a satellite. They want to get a good WiFi signal in the garage about 150ft away. Has a 1gig fiber connection, the...
Feb 27, 2024Guru - Experienced User
The problem isn't the age of the system. Its the distance and the exterior walls. Exterior walls tend to have more materials that block wifi signals and degrade the signal.
options?
1. Try and hardwire in the garage. An underground rated ethernet cable is pretty cheap and can be buried pretty easily. I've done it with putting a blade on an edge (and throwing the blade away afterwards). It doesn't get it very deep but some areas that might be fine in.
2. potentially a powerline adapter if its on the same circuit.
3. moca adapter if there's coax cable ran to the garage
4. a point to point system. They can be picked up pretty cheap. Netgear used to sell a version but its been out of stock for quite a while.
Any of these would get a connection to the garage so you could just add in a satellite in the garage. That'd be the best option.
