hummer1986
May 07, 2020Aspirant
Usb cable and ethernet cable not working
Hello! Dose anyone know how i can use usb and ethernet together? I try to share internet to both. If i turn usb on it will turn off the ethernet cable. The reason i want to use the usb cable is becau...
- May 08, 2020
this is directly from the manual:
When you are using an Ethernet connection, you can use the USB type C cable and the AC adapter to
recharge the mobile router battery.
You cannot use an Ethernet connection and a tethered USB connection at the same
time to access the mobile router. Creating a tethered USB connection puts the
LAN/WAN port to sleep. To use the LAN/WAN port later, disconnect the USB
connection, press the Power button, and wait for the LAN/WAN port to wake up.
May 08, 2020Guru - Experienced User
Not 100% because I don't have one.
When you connect the M1 to the router, are you placing the router in access point mode? The M1 has an integrated router function and running them both would have you in a double nat.
hummer1986
May 08, 2020Aspirant
Hi! I don't think i can change any modes. I find something that is called dhcp and it's on. It's confusing to me why they build this hotspot router and it can only provide one ip when a cable is pluged in. I also need to config the usb from data+charging to only charging. Otherwise it will cut off the ethernet cable. It has two outputs usb and ethernet. Wifi still works with one off these cable plugde in. I think the problem is netgear and how they build things but this dosen't make any sence to me.
- plemansMay 08, 2020Guru - Experienced User
What router are you connecting to?
- hummer1986May 08, 2020Aspirant
I'm connection to a vilfo vpn router. But it dosen't matter if it's a router. I tested to connect direct to my pc and it's the same
I get you want usb and ethernet to work at the same time. As you've said, they don't.
so your option is to get the router setup functioning properly.
You either get the MR1100 running in passthrough mode so the router is handling the DHCP
Or you get the router running in access point mode (or whatever your vilfo does)
