hummer1986
May 08, 2020Aspirant
Usb cable and ethernet cable not working
Hello! Dose anyone know how i can use usb and ethernet together? I try to share internet to both. If i turn usb on it will turn off the ethernet cable. The reason i want to use the usb cable is becau...
- May 08, 2020
this is directly from the manual:
When you are using an Ethernet connection, you can use the USB type C cable and the AC adapter to
recharge the mobile router battery.
You cannot use an Ethernet connection and a tethered USB connection at the same
time to access the mobile router. Creating a tethered USB connection puts the
LAN/WAN port to sleep. To use the LAN/WAN port later, disconnect the USB
connection, press the Power button, and wait for the LAN/WAN port to wake up.
May 08, 2020Guru - Experienced User
hummer1986
May 09, 2020Aspirant
Ok! I thank you for your support. Then i can not do anything about it. Sad they didn't program it in that way. I going to test with a usb to ethernet adapter. Maybe i will lose speed on the internet... but it's a try. Strange why im losing speed with ethernet cable. My networkscard is 1 gb/s and the mobile router is 500 mbit what iv'e found out. I understand when i connect two routers i can loose speed but not direct to my pc with ethernet cable. I'm losing around 30 mbit.
- plemansMay 09, 2020Guru - Experienced User
Try a different router. Your is a vpn router designed to route traffic through a vpn.
and make sure you're not running the double nat (dual router) setup. either the M1 in passthrough or the router in AP.
- hummer1986May 09, 2020Aspirant
Yes but i don't use vpn router when i'm losing speed. I thought from the begining that it must be the vpn router fault why im losing speed. But that was not the case. The mobile router is droping speed on ethernet compared to usb. I wonder if other people has the same issue
