Powerpill
Dec 29, 2020Follower
USB power with battery attached
Is it okay to run the modem with the battery in semi permanently on USB power? Or should I take the battery out when on USB power?
1 Reply
Its been recommend if its going to be on usb power for a while its best to remove the battery.
