PerP
Aug 14, 2021Aspirant
USB tethering with a microprocessor or raspberry pi
For low power usage: Is it possible to use the Nighthawk M1 USB tethering on a Rasberry Pi running linux OR Raspbian ...or also using a small microprocessor system such as ESP32 (Which does not have ...
Aug 14, 2021Guru - Experienced User
Are you talking about the rPi drawing power from the MR1100?
You'd probably be better off asking in the mobile router forum and not the general router forum.
