PerP
Aug 14, 2021Aspirant
USB tethering with a microprocessor or raspberry pi
For low power usage: Is it possible to use the Nighthawk M1 USB tethering on a Rasberry Pi running linux OR Raspbian ...or also using a small microprocessor system such as ESP32 (Which does not have ...
PerP
Aug 15, 2021Aspirant
Thanks....
I am not focused on the power supply but on the ability to communicate via the USB port (serial) rather than needing an ethernet connection on a low power device. The RPI Does have ethernet, but in this case I am uncertain if Nighthawk supports linux.
I posted thequestion where you suggested.
DiggyinTime
Jun 28, 2022Aspirant
did you ever get this functional?
