Cronos115
Nov 29, 2021Follower
USB Wifi Adapter can't install genie
Trying to setup my Wifi adapter but i dont have a cd drive and i tried installing the programs that it told me to but im using a macbook air to do the setup and i cant extract the .zip or turn it int...
michaelkenward
Nov 30, 2021Guru - Experienced User
Many questions are common to lots of devices but in this case your USB adapter is nothing like the "Mobile Routers, Hotspots & Modems" covered in this section.
plemans has already answered your question, but if you need more help, try the appropriate section for your hardware. That's probably here:
WiFi Adapters - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
