N4KHQ's avatar
N4KHQ
Using AT&T Nighthawk MR1100 in Bridge mode
If I put the MR1100 in bridge mode, can I connect a wifi router with an ethernet cable and access AT&T cell tower data. I can put the wifi router in bridge mode and avoid double NAT but I really need the extra features of the wifi modem. I can conect to a DSL router in bridge mode using PPPoE but don't have a clue how to make the MR1100 work. I think AT&T is using a Class A for the MR1100 IP. Thanks
    • N4KHQ's avatar
      N4KHQ
      Thanks for the reply I finally discovered how to put the MR1100 in bridge or pass through mode. Ethernet ports works but the MR1100 does not supply internet access. The light blinks orange, I thought that might be because it's in bridge mode but I could login to the MR1100 even take it out of pass through/bridge mode but could not surf. The MR1100 would connect to a Linksys EA9300 but still not internet access. It an AT&t SIM. Should not the light turn blue with the MR1100 in bridge mode? Thanks
      • Blanca_O's avatar
        Blanca_O
        NETGEAR Employee Retired
        Hi N4KHQ
        What is the IP address when connected to MR1100?
        May we please know the exact model and firmware version of MR1100?
        Blanca
        Community Team
