N4KHQ
Sep 02, 2019Aspirant
Using AT&T Nighthawk MR1100 in Bridge mode
If I put the MR1100 in bridge mode, can I connect a wifi router with an ethernet cable and access AT&T cell tower data. I can put the wifi router in bridge mode and avoid double NAT but I really need...
Blanca_O
Sep 17, 2019NETGEAR Employee Retired
Hi N4KHQ
What is the IP address when connected to MR1100?
May we please know the exact model and firmware version of MR1100?
Blanca
Community Team
N4KHQ
Feb 05, 2020Aspirant
Firmware Version NTG9X50C_12.05.05.12
ATT-WIFI-563L
Model MR1100
I assumed I was not getting a IP number for the web because the blue connect light stayed orange unitl I did a factory reset. If it not in bridge mode and my wifi router is in Bridge mode to prevent double NATing, The IPV4 address is 10.181.216.71 With Gateway 192.168.1.1 and Mask of 255.255.255.0
- jtraylorsrFeb 25, 2020Tutor
Did you ever get this to work? I am having the exact same issue. Did performing a factory reset get it to start blinking blue and work?
John
