WhiskeyLifa's avatar
WhiskeyLifa
Follower
Aug 15, 2019
Using Hotspot Offshore
I have the MR1100 on an ATT network, however, my router keeps auto switching to PetroCom (runs on ATT frequencies if I remember correctly) and will not perform well at all with data speeds. Is there anyway I can block from connecting to that carrier? I’ve tried turning off international roaming but it still connects to this network.
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi WhiskeyLifa
    Welcome to NETGEAR Community!
    Please check APN profile settings to ensure the APN profile set for ATT network. You can manually set it up via the WebUI and re-check connection.
    Blanca
    Community Team
