odhavakkara
Jan 19, 2026Initiate
Using LM1200 standalone as the internet provider
I have recently bought an LM1200 to connect to a smart cooler. It fits my bill because I can use a SIM card as an internet source and ethernet to connect to the machine. I'm testing it in my Mac ...
- Jan 20, 2026
Thanks for the responses guys. It turns out the default APN was wrong. Changing the APN from `isp.telus.com` to `sp.koodo.com` has resolved the issue.
Jan 20, 2026Guru - Experienced User
When you switched it to router mode, did you try rebooting the LM1200?
Another thing to check is the LM1200 has 2x ethernet ports. Try just using one of them in case its only handing out a single IP address.
