odhavakkara
Jan 19, 2026Initiate
Using LM1200 standalone as the internet provider
I have recently bought an LM1200 to connect to a smart cooler. It fits my bill because I can use a SIM card as an internet source and ethernet to connect to the machine. I'm testing it in my Mac ...
- Jan 20, 2026
Thanks for the responses guys. It turns out the default APN was wrong. Changing the APN from `isp.telus.com` to `sp.koodo.com` has resolved the issue.
Jan 21, 2026Guru - Experienced User
Glad you got it working! You might mark it as solved so others aren't still trying to fix it :)
