bsteder
Apr 01, 2022Aspirant
Using Nighthawk MR1100 with Remote Desktop Connection
Our business has three locations that stores it's ERP System on a remote server that uses RDC to connect to the remote server. 2 of our locations use the nighthawk MR1100 for internet access. Bot...
JohnPeng
Apr 03, 2022NETGEAR Expert
Can you try connecting a host PC to ethernet port and doing RDC from a PC connecting via WiFi? It will help to rule out the possibility that the carrier network blocks the connection.
Thanks
bsteder
Jul 05, 2022Aspirant
I’m not sure what you mean by host computer. The server that we login to via RDC is a company that we pay a subscription to and we have no access. They set up the RDC credentials and we just login from any computer that has RDC.
