timstonerrock
Feb 23, 2022Follower
Using Nighthawk MR2100 in Italy - which carrier?
Hello in April 2022 I am travelling to Italy and hoping to use my Nighthawk MR200 in Venice for work. I need to live stream video at one stage for which I will set up a bonded network with multiple d...
Feb 23, 2022Guru - Experienced User
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with Mobile (L and M series) routers. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you
