Tillygirl
Jul 06, 2022Aspirant
Verifone VX 820 not recognising ethernet cable connected to Nighthawk 2
I have a Verifone VX 820 HICAPS/eftpos machine that I wish to use in my small business however when I plug in the ethernet cable the eftpos machine states "ethernet cable not connected". It works fin...
Tillygirl
The router is an Archer VR 1600v Ver 2 and the mobile router is a Netgear Nighthawk MR2100.
It has also been working when connected to my Mac via a thunderbolt bridge, however after updating to Monterey I can use the eftpos machine but then I can't use the internet as it states its not connected. When I disconnect the eftpos I can once again using the internet.
Thanks for your help.
Jul 07, 2022Guru - Experienced User
So you're going MR2100--->Tp-link archer?
Is that correct?
or are you just using the MR2100 and plugging the Verifone into it?
