brendagalvvn
Mar 02, 2021Follower
verifying correct purchase of LM1200 LTE 4G Modem was made
I just purchased the LM1200 LTE 4G Modem and I'm thinking of using a cricket wireless sim card. However I don't know if this model will be compatible. I went on the cricket website and in order to ve...
michaelkenward
Mar 03, 2021Guru - Experienced User
brendagalvvn wrote:
Another thing, i feel like its a silly question, but is this device "unlocked" i know if it can be used with any provider the device being "unlocked" should not be an issue, just wondering.
Not at all silly. A device is "unlocked" if it is not tied to a particular mobile operator. Locked devices are usually supplied buy the operator. They offer a discount and/or a contract to lock you on to their network.
brendagalvvn wrote:
I went on the cricket website and in order to verify its compatibility I need the IMEI number which i don't have yet.
The LM1200 seems to be a new device and Netgear hasn't got round to producing a complete manual.
Look at the label on the bottom. That should have an IMEI as well as your model number.
