shiphranita
Mar 29, 2018Aspirant
Verizon Novatel USB760
I have a Novatel USB760 stick from Verizon that I am trying to use to connect with my new Netgear Nighthawk AC3200. The USB stick won't connect at all. The connection is usually automatic on my Cradl...
JasonN
Apr 02, 2018NETGEAR Employee Retired
Hi shiphranita,
I could not find anything on the compatibility between the Verizon Novatel USB760 & the NETGEAR AC3200.
Please contact support and they will be able to help you with the issue.
http://www.netgear.com/support/contact.aspx
Please let me know. :]
- Jason N
