shiphranita
Mar 29, 2018Aspirant
Verizon Novatel USB760
I have a Novatel USB760 stick from Verizon that I am trying to use to connect with my new Netgear Nighthawk AC3200. The USB stick won't connect at all. The connection is usually automatic on my Cradl...
JasonN
Apr 05, 2018NETGEAR Employee Retired
Hi shiphranita,
I wanted to check in with you and see if your have got this issue resolved by support.
Please let me know. :]
- Jason N
shiphranita
Apr 05, 2018Aspirant
Well the resolution is that it won’t work.
- JasonNApr 05, 2018NETGEAR Employee Retired
Hi shiphranita,
Thank you for confirming because that was the only results I have seen when researching on the compatibility.
- Jason N
