J007
Aug 01, 2022Tutor
Verizon Wireless with Orbi AX4200 5G WiFi 6 Router (NBR750) disconnects from Verizon network
My Orbi AX4200 5G WiFi 6 Router (NBR750) with Verizon Wireless disconnects from Verizon network. The SIM was setup as a BYOD but seems to still have a provisioning issue. I’ve tried two different NBR7...
J007
Aug 04, 2022Tutor
Verizon has verified the APN (vzwinternet) and has provisioning three different SIM cards and multiple tier 2 tickets have been created with Verizon to verify provisioning and features. The netgear device continues to disconnect from the Verizon network. I’ve moved the new SIM from the netgear Orbi to my old novatel t1114 device and the old device works and doesn’t disconnect from the network. Can netgear confirm the exact SIM provisioning and features needed to make the Orbi work? Verizon says the device is not supported and that this is a netgear issue.
Blanca_O
Aug 08, 2022NETGEAR Employee Retired
Hi J007,
Thank you for responding. We are looking into this. I sent you a private message requesting for additional information.
Blanca
Community Team
- seanreillyAug 17, 2022Aspirant
I'm encountering what sounds like the exact same issue with the NBR750 and Verizon 5G using a bring-your-own-device SIM. I'm happy to provide any information necessary if you can help make it stop disconnecting. Our previous netgear verizon-provided 4G/LTE router has worked flawlessly for years.
Thanks,
Sean
