Ant100uk's avatar
Ant100uk
Follower
Nov 04, 2021
Virgin 1gb
Hi all
I'm hope some one could help me and this is my first time posting.
im planning on getting virgin media 1gb fibre at work all ready have swiches set up etc... I would like to know which router I should buy to connect to the virgin box and will it work with virgin
AX11000 WiFi Router (RAX200)
also I seen on YouTube they connect both boxes via the nighthawk app and not via the admin
1 Reply
  • plemans's avatar
    You should be able to connect an RAX200 to the virgin gateway without issue.
    the only thing I'd caution is a lot of time, virgin gives you gateways with built in routers. Those you can either put in passthrough mode or put the netgears IP address into their DMZ
