Vetch
Mar 26, 2024Tutor
VPN - Nighthawk m6 pro
Hello , iim looking for someone advice on adding open VPN on the nighthawk m6 pro . Is it possible? If not is it possible to add any vpn to the device
Thanks.
Thanks.
usually adding a vpn to a router requires 3rd party firmware to be installed and 3rd party firmware is rare (to non-existent) on hotspots.
some travel routers (not hotspots) support them but usually you have to connected the hotspot to them.
I use a gl.inet travel router and have a vpn installed on it. You could do something like that and use the M6 as just a mobile modem and the gl.inet as the router.
most devices can use/have a vpn.
there are paid services that you simple install a app/program to your device.
or you can use the free ones that are more user intensive.
Just look up your device in google for "vpn android" "vpn apple"
And there'll be a bunch you can choose from to look for device specific vpns.
- VetchTutorHi thanks for the reply, I do have a vpn paid subscription but I’m not sure how to add it to the nighthawk m6 pro or if it’s possible to add a vpn , normally you can add a open vpn file but I don’t see anything in settings, I did look on YouTube but found nothing about adding a vpn to the m6 pro .
To add it to most routers/hotspots, it has to be compatible.
What VPN do you pay for?
It might not be possible to install it to the M6 but just installing it to the devices you connect
