sgtberger1
Aug 28, 2022Follower
VPN setup for Nighthawk M5 MR5200
What I have found so far:
-LTE routers generally are not set up to have VPNs because of the strict NAT provided by mobile network providers
-VPN passthrough is enabled but not configurable on the M5
Things that are configurable:
-IP passthrough, port forwarding and port filtering are possible.
-DNS settings are configurable
Does anyone see a way to input Expressvpn manual settings for a solution with L2TP,PPTP, or IPsec configuration?
Additionally, would it be an option to have a wireless router connected to the LAN port with IP passthrough, and enable a VPN service on that WIFI router?
No RepliesBe the first to reply
