lund33
Feb 23, 2018Follower
WAC120 DETAILED installation help for newb
I am about ready to put this thing in a vice and burn it. I do not understand anything that is not plug and play. I have had this thing for almost a year and I cannot for the life of me figure out ho...
JasonN
Mar 01, 2018NETGEAR Employee Retired
Hi lund33,
I just wanted to check in and see if this has fixed you issue.
Please let me know :]
- Jason N
- Juliwade01Apr 29, 2018AspirantCan anyone help. I had everything set up and running fine, but after my son rebooted our main hub (I use the wac to extend the Wi-Fi so I can use in my attic room) the previously connected devices all see it but fail to obtain the up address
- MAGADEApr 29, 2018Guide
Hi, perhaps a conflict IP adresse due to DHCP reservation faulty.
The reboot perhaps stop IP lease.
try to assign IP adresse of router LAN port or hub LAN port in a DHCP RESERVATION.
- Juliwade01May 11, 2018AspirantHi Magade
Can you/someone advise how I check this and rectify?
Cheers
Julie
- JasonNMay 03, 2018NETGEAR Employee Retired
Hi Juliwade01,
I just wanted to check in and see if your issue has been resolved. If not, have you tried MAGADE's suggestion?
Please let us know. :]
- Jason N
