lund33
Feb 23, 2018Follower
WAC120 DETAILED installation help for newb
I am about ready to put this thing in a vice and burn it. I do not understand anything that is not plug and play. I have had this thing for almost a year and I cannot for the life of me figure out ho...
Juliwade01
Apr 29, 2018Aspirant
Can anyone help. I had everything set up and running fine, but after my son rebooted our main hub (I use the wac to extend the Wi-Fi so I can use in my attic room) the previously connected devices all see it but fail to obtain the up address
MAGADE
Apr 29, 2018Guide
Hi, perhaps a conflict IP adresse due to DHCP reservation faulty.
The reboot perhaps stop IP lease.
try to assign IP adresse of router LAN port or hub LAN port in a DHCP RESERVATION.
- Juliwade01May 11, 2018AspirantHi Magade
Can you/someone advise how I check this and rectify?
Cheers
Julie- JasonNMay 15, 2018NETGEAR Employee Retired
Hi Juliwade01,
Have you tried doing a factory reset on your device? Please hold the reset button on the back for 10-15 seconds and let the unit boot all the way up.
Please let me know if this works for you. :]
- Jason N
- Juliwade01May 16, 2018AspirantI tried the factory reset. Had to also turn off/On before WiFi would begin broadcasting again. I now (still) have an access point that my devices can see but fail to access up address, with the added bonus that I am now no longer password protected, so will have to reset that if I ever get things working again. So no unfortunately it has not solved the problem. Sorry if this sounds sarcastic but getting a bit fed up, especially as this is a replacement wac120 only got it from Netgear in Dec 2017.
