bruce1946
Apr 02, 2021Follower
wall plug loses connection
My netgear nighthawk mr1100 works as it should using the battery and the usb to usb but as soon as i use the netgear supplioed 110 wall plug i lose conection on my computer, phone etc.
Is there a setting i am missing?
The RMA replacement unit netgear senrt me has the same connectiopn loss as the previous 3 other units my original purchaser replaced. HELP!!!!!!
1 Reply
- W1lliamVirtuosoYou’d better to buy another wall plug charger (with USB port) which supports QC3.0, would be great if 5V/3.5A or above is supported. M1 is rely on stable current supply at certain level, it is fine for phone to charge at less current (just take longer charge time) but not ok for M1 and it will just reboot due to minimum current is not satisfied at that moment.
