sripley12's avatar
Dec 05, 2023
WAN Failover to 5G
Hey folks..
I've got the NBK752 configured as ethernet (from my ISP)  as primary will failover to EE (UK) 5G if ethernet fails...
The issue I have is the failover doesn't appear to be working:-
Router shows 4G connection status as connected with WAN IP etc but there is no onwards connectivity to any devices on the network. If I try to a n/w speed check on the router itself then even it says its not connected.
Once the router is rebooted works all perfectly - but I'd kinda  hoped it was fully automatic and as a travel a lot and really didn't want any manual intervention. Is there a setting somewhere I've gone wrong?
Thanks in advance
Simon
No RepliesBe the first to reply
