MiFireGuy
Sep 14, 2019Follower
WAN not found using LTE
Hello!
I am trying to link my MR1100 to my R7450 via the WAN port on the router. I have went into the MR1100 and turned off wifi, enabled ip pass through, turned off the dhcp, and disabled the 2 minute ethernet connection. No luck
I also went in and changed the DNS & IP configurations to ISP Automatically Sets instead of using Static.... still no luck.
It shows that they are communicating because when I go back into the 7450 you can see where the 1100 set the ip and DNS. I also know the 1100 is working because if plug ethernet cable directly into my laptop it connects just fine.
I feel like I'm missing something simple here... Any help is appreciated
- Blanca_ONETGEAR Employee Retired
Hi MiFireGuy,
Welcome to NETGEAR Community!
What is the IP address when connected to MR1100?
May we please know the device SKU (MR1100-100xxx) and firmware version of MR1100?
Blanca
Community Team - TimRyAspirant
Try your config, but do not enable IP passthrough.
- TimRyAspirant
Depending on your ISP - enable 'DHCP' for the internet connection type on the router that is connected to the M1.
