david70
Aug 13, 2015Follower
web admin password not enabled
Hello everybody, I have bought a aircard 785 mobile hotsport and when I try to set the administrator password in the web home page setting, but it isn't enabled. Any suggestions, thanks. Davide
DarrenM
Aug 14, 2015Sr. NETGEAR Moderator
Hello go4dutch and david
I was able to test the 785 aircard I have and was able to change the admin password. You may want to try a different browser if its not working for you I used chrome and it work. next make sure you are logging in as admin so it allows you to change settings. if those dont work try to do a factory reset on the aircard. hope to hear your feedback
DarrenM
DarrenM
If this issue is still happening can you give me some screenshots so I can pass them on to engineering
Thanks
DarrenM
- maggioAug 19, 2015Aspirant
tried to uses several browsers: Safari, Chrome,firefox and IE
same result since last automatic firmwareupdate only the standard passwort will work and this is not changeable on webinterface.
There is only a Admin entry but no field you can place the cursor to put in an alternative password.
BR
Maggio
- DarrenMAug 19, 2015Sr. NETGEAR Moderator
I have passed this issue onto our engineering team they are currently working on a fix but I dont have a ETA on that ill post back once I hear a update on the fix. let me know if you have anymore issues or questions.
DarrenM
